Pyronix Enforcer beeps for 7 seconds before setting
8 Aug 2024
Hi All,
Upon setting, My Pyronix Enforcer beeps 7 times for 7 seconds before starting the setting timer (15 Seconds continuous tone)
Is there a way to stop the beeps and go straight to the 15s setting timer after you enter the code?
Thanks in advance for any help.
Cheers, Tony.
Set the zones exit volume control to 0 for silent, 1 for silent exit but confirmatory beep and 2-7 for the audible beep you mention.
Thanks for your quick response.
But that silences all beeps, I want to stop the 7 beeps for 7 seconds, but still be able to hear the continuous 15s exit time beep
Ie after code is entered the alarm goes immediately to the continuous 15s exit time beep, without sounding the 7 beeps for 7s.
Thanks,
Tony.
I think the OP is referring to the arming beeps Sparky then they are getting the continuous beep
If that’s the case the option I’ve gave is the option. You can’t seperate the arming beeps from the countdown
What arming bleeps ? Intermittent tone means a zone open ….continuous all clear …..
Code
A, B, C, D
Yes
I’m not at a panel just now but don’t you get the intermittent beeps whilst it’s arming with please wait on the LCD then the intermittent or continuous dependant on the exit mode?
OP is referring to Exit Route tone so hallway activating upon exit route. Only solution to this is as mentioned silent the exit tone, get the app or a keyfob-we and arm from outside save using the keypad and hearing the tones
Thanks all for your comments.
to DIYSOS2018 - 0 silences all beeps. 1 does the same except for confirmation beeps, 2-7 alters the volume of all exit beeps.
to sparkymarka - no sensors in hallway (exit route) only a door magnetic contact, so don't think its a sensor error, yes if you open the door during the 15s continuous exit tone it changes to a beep, beep, beep,........ But always does 7 beeps before the continuous exit tone, whatever you do.
Don't know if this makes a difference, but we are entering the code on a remote keypad, not on the main panel.
It's mystery.
Tony.
Wireless I think, but I didn't install it, it was there when I moved in - see picture, if that helps
Well I’ve just learned a wireless keypad onto an enforcer and there’s no intermittent bleeps
All devices closed
It does this whilst arming the wireless devices before the exit period starts. You can stop it by not using any wireless devices.
