Pyronix Enforcer fault reset after battery change
2 Jan 2020
I have a Enforcer panel RLBL 1349-3 this alarm was installed already when I moved in.
With no codes or manuals I had a Engineer come in and service and reset it.
It had low battery warning and I changed the battery but still get a low battery warning fault on my panel.
I have tried to the Engineer to come out but he has ignored my calls. How can I clear the fault I have asked him for the Engineer code as well but he still hasn't replied to me.
Very vague, cant speak for the engineer as to way you haven't been able to get through to them but it was Christmas with many going back to work today and some not until Monday.
As for your low battery warning, the question is which battery and was it the same device as the battery you replaced?
Hi It was low battery warning on bedroom sensor anti tamper I think it's called.
I changed this battery and still got low warning I also swapped the one from the bathroom to see if it would make a difference. The power is there as I get 3 blue dots coming up on the sensor.
(It was a friend of the family who recommended the Engineer and they have separated so that may be the problem)
I just want the alarm sorted as easily and quick as possible.
Thanks for your assistance it is appreciated.
if things have been done properly and the devices properly closed there should be no faults displaying.
If you have the engineers code going in and out of engineering should clear all faults that have been addressed, if they still show you need to look at the device the system is indicating there is a fault with.
I do not have the Engineers code only the user code. is there a way round this.
you could power cycle the unit and then use master code to reprogram time and date I guess.
battery off , mains off, battery reconnected, then mains back on.
enter maser user code and program time and date
but doubt it will help you if the battery replacement hasn't been done properly
Ok I will try to power off. I have changed the batteries with another brand and I have now ordered the exact same one that was in it to see if that makes a difference.
If not I will just get a new Engineer to service it. Thanks for all the replies.
I doubt the brand would make a great difference to be honest as long as it's the same type, longer term you may see a difference between some batteries.
