Pyronix Enforcer: Setup question
22 Nov 2019
I have a V10 all configured with a single Area working fine.
However I want to reconfigure it to cover the shed independently of the house so that the shed is usually set unless they are being accessed and the house can be set separately. Both should be set/unset using an RFID fob.
I have set up two Areas on B & C (House & Sheds) and have assigned an RFID fob to each sheds . That works fine, so does the house setting. BUT if the shed is set I cant then set the house unless I unset the shed first. The unit just beeps and doesn't set the house.
Any clues would be appreciated before I start experimenting further!
Kevin
Cracked it! For others looking for the solution there is a setting Engineer Menu -> System Options -> Site Options -> Use Level Set (Default:Yes) which if set to No allows Areas to be set independently.
