Pyronix Enforcer v10 hard wire a siren
Isn't the word 'actuating', it's what I and others I know have used for c.100yrs between us?
I'm new to the forum.
I have 3 wired Deltabells to install is it a case of wiring in parallel as per Jonny08's pic?
Many thanks,
M
Thanks Sparkymarka - so for completeness and for others who may find this thread in the future - like this?
Sorry to Hijack!
How many deltabell siren can you successfully wire into the enforcer?
I’m assuming wire them in parrallel bar the tamper which would need to be in series?
One unless you are going to fit a power supply with battery back up , you could hardware one plus two wireless sounders
Thanks! The only disadvantage I’ve found with the wireless ones is that there’s no backlight option with them being powered by a battery. Would be good if there were an option to add a 12v supply for a backlight.
You can’t use an encapsulated psu to power a delta bell plus , you can on a wireless but that hasn’t got backlighting ...
Hi, I thought I'd revive this thread rather than starting a new one. I have a few questions about the wired bell box. Any help would be greatly appreciated
1) can the bell box be wired with just the siren/strobe/12v+/12v-. Thus leaving out the tamper circuit altogether? Also in this case if the internal battery is enabled in the bell box would it sound the siren in the event that the alarm is triggered if 240v was lost to the control panel?
2) when wiring the resistor into the tamper circuit can the resistor be wired (as a jumper) between the T and 12v-?
3) if using a lighting module would the inbuilt battery in the bell box also power this in the event of loss of power from the main panel?
I'm aware that the main control panel also has battery backup but I'm unsure in what instance the bell box battery takes over.
The bellbox battery is there ..So if someone breaks in your house and smash your control panel off the wall IT WILL STILL RING OUTSIDE ...for 15 mins depending on bellbox make and model
Thanks sparky..would this still be the case if I left out the tamper circuit? the bell box will be high up on the house. the sounder module is pyronix FPDELTAX
