I have only 3 old PIRs then I will replace them and we will see if this help
LED street lights are 12m away from house - is this is enough to cause problem?
I don't really want to switch off jamming protection
Changing setting from 030 t0 100 will make difference ?
The only way that might help is if the signal strength from the new sensors is strong enough to cut through the signal jamming the communications between sensor and control panel.
During day I had another jamming issue and after that when I check app I found message about tamper was activate / lid open (one of old PIR sensor) but lid is closed
