Pyronix euro46s
6 Mar 2018
I've just intalled the euro46s on my home everthing is setup and working my only issue is the front and back door input type
I want the f/b doors to be timed entry exit on a=full and b=night set I want the doors
Intruder I've tried the input types 07 to 10 in the manual but I don' get the desired results.
Any help is appreciated
Lee
What does zone type 10 do in A and B ? Think the 46 does full plus , A-D slightly different to the mini / enforcer but I may be wrong
System Options -> Exit Modes
Make sure they are both set to timed. I suspect area A default setting is contact set.
The doors need to be type 07.
Detectors need to be type 08 entry.
Type 10 is
Fx (AREA) when fullyset acts as final exit when part set acts as entry route.
Type 10 was my first thought but when set the alarm In either a or b the alarms sounds when i open the door with no timer which is what I want for b but not a
My exit mode is set to timer
I could change the type to 07 then set the entry time of b to 0 which does give me my desired effect but I assumed there might be a proper setting for this rather than a hack of sorts
