Sorry to be a pain, but in a previous post you mentioned plastic pipe (Hep2o in this case) needing to be barriered. Would it be possible to explain what this is?
Plastic pipe is porous to air. That doesn't matter with for example a cold feed, but on a CH system, it'll suck small amount of air into the system through the pipe walls. This causes corrosion and other problems.
Barrier pipe has an extra non-pourous layer in it, it's more expensive, but you need it for heating.
Thanks Slippy I have also checked out www.Hepworth.co.uk which was quite useful.
If it is not barrier and has to be changed can I leave until the winter is over before doing so i.e. would the air over the next say four months cause immediate corrosive damage to the system.
Come to think of it if it is wrong it's been wrong for two years now so I'm probably stuffed.
Hep20 non barrier pipe is ok for CH as it says so on the side of it, just make sure there is adequate amount of inhibitor in and it will be fine, stop worring and enjoy christmas.
