I want to run 3 x 35w low voltage lights off a transformer. I have purchased a transformer that runs up to 105w. It has 4 x terminals on the outlet. Would I run 2 x lights into two of the terminals and the last light into the other two terminals?
In that case you'll be running the transformer at its maximum rated output. Could you not get a unit with more capacity?carlsbergy said:I want to run 3 x 35w low voltage lights off a transformer. I have purchased a transformer that runs up to 105w.
carlsbergy said:Thanks for your replies, much appreciated, if I do decide to keep the transformer I have, do I connect two of the lights into two terminals of the output and the remaining lamp into the other two terminals of the output?
electronicsuk said:remember a 35w load @ 12v is nearly 3A, and any voltage drop across the cable will be quite noticeable too.
fattony said:electronicsuk said:remember a 35w load @ 12v is nearly 3A, and any voltage drop across the cable will be quite noticeable too.
hmmm is that strictly true, I understand where you got that figure from but its a resistive load so the calculation would be different from P/V, think about 10 low voltage downlighters in a room would = 30Amp
fattony said:I see your point, I've never really thought about a 12v light 35w bulb calculating to 3Amp, do the low voltage downloghters cost more to run then the 230v GU10's
