I have had a Baxi duotec 28 fitted, no external controls, just a digital timeclock and the standard temperature controls for the outputs.
I have 6 radiators. 4 of these have thermostatic valves.
I have noticed just recently, the boiler seems to cycle a lot (igniting say once every 10 mins) and this co-incides with the times when the 4 radiators are closed, so all the heat is being pushed through 2 radiators.
The 2 rads without TRVs are in the bathroom and hallway, which really do need heat all the time, as they are the coldest rooms in the house (lots of external walls, front door in hall, only a towel rad in bathroom).
Is this cycling doing any harm?
I had thought about having a thermostat installed in the hallway, so when this is at temp, the boiler shuts off.
Also, I have read that the return water should be at around 50 degrees for maximum efficiency, is this right? How do I tell? The flow is set at 65, though I guess the return will vary depending on the number of rads open.
