question for the genius people on here
26 Sep 2007
Southampton
A defibrillator delivers electrical energy at 360j
Is there a formula that will convert Joules DC to watts volts amps?
I've not been able to find one yet just wondered if any of you pro's knew
Thanks in advance
Joule is a unit of energy
Watt is a unit of Power
The two are related by Power = Energy per unit time (second)
C.F the amount of electrical energy you consume is measured in Kilo Watt Hours.
So for the 360 J defibrillator the voltage/current and hence power will be time dependent
so if it is used for 1 second then 360 watts of power will be used
1 joule is 1 watt per second.
As for amps/volts - can't be obtained without already knowing one of them (and the time over which the energy is released).
Hello
1 Watt = 1 Joule per second of power ?? :shock:
Does this help ?
Ed
too slow again :(
Thanks Guys
Discharge of energy is over 2mSec the discharge graph shows a + deflection of 2500v and a - deflection of 2500v (Biphasic cycle discharge )
No idea who Jikwan is.
Just trying to ask a question from a knowledgeable body of experts
OK - I just wondered if you were, and if a DIY defribrillator made out of sawn up breadboards and powered by free electricity from water was your next project...
No offence meant....
None taken
Why woudl I want to cut breadboard??
I teach people how to use defibs and am just trying to give them a frame of reference in terms of the energy delivered that they can understand
