Question regarding a new hot water cylinder
2 Aug 2007
People,
I have an existing hot water cylinder which measures around 18 inches in diameter x 36 inches high. I understand it is called a 'standard' hot water cylinder.
I require it to be replaced. The existing cylinder has a feed in at the bottom, an output at the top, feeds to the coils and also a feed to a power shower pump.
My plumber has advised me on a price for a new copper cylinder which is going to be around 18 inches across but by around 48 inches high therefore increasing the capacity.
The question I asked my plumber was whether or not a stainless one could be fitted instead of copper and he advised that these were generally for high pressure systems and not like my existing system which has a cold water tank arrangement. He said good copper cylinder nowaways should last 15 years.
Can someone advise if it is possible to obtain a stainless replacement for a copper cylinder which would allow for the connections above and also how they compare in cost to copper??
He has said that if I can source a stainless one suitable for my system then he would be able to fit it.
Many Thanks
Paul
thanks Hob, Im always a bit wary of Screwfix on this sort of item, can you provide a link to a really reputable manufacturer?
Your plumber is talking out of his arris I'm afraid. Stainless are indeed available for low-pressure systems and, as hobhead has already said, are now cheaper than copper ones due to the surge in the price of copper.
We use the Gledhill Envirofoam cylinders http://www.gledhill.net/pdf/EnviroFoam Stainless.pdf, our local City Plumbing has now virtually ceased stocking copper cylinders and stocks these instead. They make one in the size you require and there is a tapping in the side for the shower pump as standard. 10-year warranty but should last much longer.
