I have an external socket which is run back to a 16A MCB under RCD protection in my consumer unit.
I currently do not have any wiring connecting my immersion heater at my hot water cylinder. It looks like it used to have wiring but at some point (presumably when electrics were done) they decided not to bother with the immersion.
If possible I would like to be able to connect this up. I have read other posts about immersion heaters and the fact that usually these are on dedicated 16A circuits to the consumer unit due to the power they consume, but I have also seen posts where people have advised that it may be possible to run off another circuit if that circuit does not get used heavily.
I do have a spare way in my CU but don't have a 16MCB (only a 6A - presumably what the CU came with - this isn't in the CU by the way there is a blanking plate) I know I could buy a 16A MCB but am worried about overloading the RCD (even if all circuits are not being used at the same time.
Therefore as the outside socket is only used occasionally when I cut the grass would it be possible to use this for the immersion circuit as well?
By the way I have no intention of doing this myself but would like to have an understanding of whether this is possible before contacting a local electrician.
Thanks for any help.
