Hi. I've been prepping some interior walls and door frames for painting with matt emulsion and matt gloss. I've sanded (painted) walls and frames and started filling small plasterboard holes with Gyproc easyfill. However, the easifull started going off after about 15 minutes so I'm guessing it's out of date, so i stopped. I don't think the walls are in too bad a shape, but there are a few small areas where the paint has flaked.
I've got a few questions for the pros
Is easifill the right product to be using?
Can I use the easyfill to go smooth over where the paint has flaked?
I've come across a lightswitch box that's been patched over (badly), is it a good idea to fill this with the easyfill?
Should i prime the walls for a better finish and what should I prime with?
Thanks in advance
Thanks in advance
