I've got an empty plastic pond - sort of kidney shaped 2mx 1m with shelves around the curves of each end and want to get some plants in. It had no water, but recently with all the rain has become half full! It's a bit murky and smelly at the moment (there were some rotted leaves at the bottom when it was empty.) What would the pond minded among you recommend for creating a nice little pond.
a few points:
1) should I remove everything from the bond and give it a clean (if so what with)
2) should I let the rain fill the rest of the pond to the top (what about the murky looking stuff already in it)
3) any recommendations for plants (for the shelves and floating on the surface.
4) is it possible to not use a filter (no electricity nearby, for at least 30m)
5) how can I stop the water going green and smelly
6) The few ponds I have seen have hundreds of little flies/midges type things swarming around. Can that be prevented?
oh, the pond has sunlight for aound half the day, is that good or bad?
thanks in advance.
a few points:
thanks in advance.
