Am redoing the kitchen and need to add an extra double socket on the other side of the room ( so putting it into the existing ring would be awkward ). This is in a bungalow, so all the wiring is in the loft.
I already have one spur ( from the main ring ) which is running the socket for the boiler and nothing else ( just has a double socket on it ).
If I took this spur, first ran it into a 13A FCU ( before any sockets ), would it be OK to add the one double socket for the boiler to this, then just connect the new double socket ( will just be running a kettle ) onto the first socket ?
I know you arent supposed to run a spur from a spur, but if it is going into the FCU first, so is protected, would this be OK ?
Ta[/img]
Ta[/img]
