just finished decorating a room, had it all planned in my head and when ive come to fit everything in the way i planned it doesn't fit, the bed is going to have to go in a completely different place, and now the sockets and switches need to be moved. I can live with them where they are for now but the main thing ill need eventually is some plugs behind the bed side tables in the new location.
the setup is all brand new wiring to regs installed last year by the same professional who will do this work if its possible.
the wall the the bed head is now on is a shared wall with a small bedroom the other side.
question instead of ripping up the new floorboards, new underlay, new carpet, new skirting and then chasing the walls and perhaps being murdered by the mrs. Can i chase the wall on the other side with the cables passing through the wall directly into the sockets, so i only have to chase out the socket on the other side of the wall, or would this be against regs because no one would know where the wires were?
if thats the case could you do the same but have a socket on both sides of the wall in the same place?
thanks
thanks
