Quick question as I need to do this soon...
Wall from outside in will be:
Renderboard -- 25mm air gap/battens -- || 12mm plywood -- 12mm OSB2 -- 96mm studwall || -- 12mm plasterboard
The part between || these lines || will rest on the perimeter bricks.
Should I do this (block will be cut down to correct size but is it the correct material for the job since it looks like a sponge!?):
or this (notice brick isn't wide enough for wall and maybe harder to drill into?):
As mentioned in other thread really don't wanna be drilling into the concrete base.
Thanks in advance.
Thanks in advance.
