    Dismiss Notice
quick question regarding fitting 1 gang socket to spur
Discussion in 'Electrics UK' started by sunshinewelly, 11 Oct 2017.
  1. sunshinewelly
    sunshinewelly
    18 Sep 2017
    55
    Thanks Received:
    Country:
    i have had a fake (plaster board over batton) chimney breast removed in my living room. it looks as if previously there may have been some heating installation behind it as there were some copper pipes running behind the fake chimney (they were not doing anything as they were cut off at the bottom and were also cut where they hit ceiling floorboards and were wedged in a gap)
    there was also a 2.5 cable running down the wall behind the old plaster board which was run to some form of small white fused box (there was a separate smaller gauge wire coming out of the box which had simply been cut and taped over . there was a channel cut into the wall where this box and wire was
    i have had new plaster board put in place and want to put my tv there. I took the fuse box off the wire and i have attached a single power point to this lead and have tested an appliance on it and it works fine.
    is it ok to run my TV off this cable. the TV power output is around 150w
    i am not sure if its part of my downstairs ring or a separate ring
    i do have a space on my consumer unit which says "immersion circuit" but i dont have any immersion heaters. I do have a combi boiler in kitchen and a seperate shower circuit and cooker one etc
  2. ban-all-sheds
    ban-all-sheds
    27 Aug 2003
    69,784
    Thanks Received:
    2,857
    London
    Country:
    It might be, it might not be.
    Basically this:
    may have been premature.
    You need to find out:
    • What type of circuit it is (ring or radial).
    • What is the rating of the fuse/MCB for that circuit.
    • What size the main circuit cable is.
    • What else is supplied by that spur or branch.
  3. sunshinewelly
    sunshinewelly
    18 Sep 2017
    55
    Thanks Received:
    Country:
    The fuse box was cracked so unusable.
    I assume a standard combi boiler does not require a separate circuit. The combi says it has a 3 amp fuse etc
  4. ban-all-sheds
    ban-all-sheds
    27 Aug 2003
    69,784
    Thanks Received:
    2,857
    London
    Country:
    But it was replaceable.
  5. sunshinewelly
    sunshinewelly
    18 Sep 2017
    55
    Thanks Received:
    Country:
    What would change by replacing a fuse box with a one gang socket
  6. ban-all-sheds
    ban-all-sheds
    27 Aug 2003
    69,784
    Thanks Received:
    2,857
    London
    Country:
    That would depend on what design assumptions were made for that spur/branch.
  7. Sponsored Links
  8. sunshinewelly
    sunshinewelly
    18 Sep 2017
    55
    Thanks Received:
    Country:
    Just did a quick test and found it's on the downstairs ring. The TV was usually being run from an extention lead.
  9. ban-all-sheds
    ban-all-sheds
    27 Aug 2003
    69,784
    Thanks Received:
    2,857
    London
    Country:
    Anything else on that spur?
  10. sunshinewelly
    sunshinewelly
    18 Sep 2017
    55
    Thanks Received:
    Country:
    As far as I can tell no.
  11. ban-all-sheds
    ban-all-sheds
    27 Aug 2003
    69,784
    Thanks Received:
    2,857
    London
    Country:
    Then as far as we can tell it will be fine with a socket in place of the FCU.
  12. sunshinewelly
    sunshinewelly
    18 Sep 2017
    55
    Thanks Received:
    Country:
    Cheers. Originally there must have been some device running off that fused box. Not sure what though. Would an old boiler use a spur. Just curious as to what would have used the spur in the first place
  13. Taylortwocities
    Taylortwocities
    28 Jul 2006
    19,077
    Thanks Received:
    1,913
    Oxfordshire
    Country:
    Sure, could be. Or a whole host of other possibilities that it is not worth worrying about.
    As BAS posted....
  14. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
