Quick Shower Room Lighting Q
7 Jan 2014
West Glamorgan
I'd like to change the batten fitting for a nicer light fitting. Am I ok to go for any fitting that is IP44 rated. I'm after a flush-to-ceiling type, so no dangly bits!
Thanks.
CG
Well - the answer to the specific question you ask is 'yes'.
However, there are other lights which would also be acceptable - including a bare pendant in the correct place.
Thanks for the reply. I'm assuming IP44 fittings will be to a higher safety standard? That allows me to let Mrs CG loose on the internet with a target to look for.
Sort of.
Things like showers can go in zone 1 if they are minimum IPX4 - splashproof (The X means that number can be anything).
So a light on a ceiling more than 2.25m. high can be any IP if the manufacturer states is suitable for a bathroom.
