Quick wood cutting question
14 Mar 2008
Hi I need a piece of treated timber cut lengthways so that it is 1cm thick on one side and 3cm thick on the other (looking at 1.8m long - it's for a fence run where there is an angle change). Would a timber yard (Huws Gray for example) be able to do this? I basically want a custom made triangular piece of wood. Thanks
Triangles tend to have three sides, 1cm X 3cm x ?
Sorry I didn't mean a triangle exactly! Say 5cm by 5cm by 180cm cut down the length so that it's then 4cm by 2cm
if you work out the angle then it can easily be done on a table saw so you need to find somewhere or some one with a table saw or planer table
