Quinetic - How to connect?
27 Sep 2011
I am referring to the wireless switch/receiver which companies like TLC sell
I have a ceiling rose which has one cable coming in feeding the power and one switch cable
Can anyone advise on how to install the Quinetic wireless receiver please? I have looked online and i am still not certain
Also, to be compliant with today regs the receiver needs to be mounted to a suitable enclosure.
What mount would work best?
I would like
The QUR003 receiver has live and neutral in and Live and neutral out. How can there be any Confusion ?
is it more that you do not understand the pendant wiring?
post pics of the bit that you need clarification of (not sure if that’s proper English but CBA to edit it!)
I guess you have choices!
1) under the floor boards upstairs
2) on the ceiling next to the light!
What are you hoping to gain ?
Thanks for the help guys
I have two lights in my bedroom
One main light and one bedside light
They are both controlled by a switch by the front door
I want to have the bedside light turn into a two way light, so that i can switch this off while in bed
From the videos, I think i can meet this objective by doing the following. Please let me know if I am wrong :D
1. Replace existing front door switch with this
https://www.tlc-direct.co.uk/Products/VLXYPGY2MB.html
And two of these to create the two gang switch
https://www.tlc-direct.co.uk/Products/QUGDVL.html
2. Then buy two receivers and install these by both lights in the ceiling loft
3. Then buy this and place it by the bed to create the two way bedside light
https://www.tlc-direct.co.uk/Produc...MI85qozbbJ6QIVxvZRCh0zQga8EAQYAyABEgLU5_D_BwE
Does this sound right?
To comply with todays electrical regs do I need to mount the receiver or put it in an enclosure of any sort?
I would put a 2 way pull cord switch in the ceiling above the headboard.
Running 3 core and E to the other switch
Not a bad shout.. However my missus hates pull cords :D
and I don't want to chase the wall as it is made of crumbley crappy breeze block
Also, the Quinetic would give more freedom in terms of positioning and future repositioning.
You have a loft above the bedroom ?
Can you fit receivers near one of the lights
Yes, the loft is above the bedroom and the receivers can be fitted next to the light
Well I guess you need to pull the 2
Cables out the light. Leave switch disconnected. Power Into an adaptive box. New cable to both lights.
Fit one to two receivers in box.
2 if you want to control lights independently.
Many thanks. I've successfully connected the lights using the Quinetic receiver/switches
What I would like to know is whether the receiver can be left by the light in the loft area, or does this need to be encased in some way to comply with current electrical regulations?
it needs to be encased.
As the single insulated wires shouldn't be exposed
What would be suitable to use?
Or can I use anything (e.g. hard plastic) I want as long as the receiver/wires are encased?
