Hello, wondering if someone could help with a query I have. I have recently purchased a Quooker Nordic Single Tap and a Pro 3 tank. Quooker have clearly stated on their website that this can be used "with your own mixer tap", however, the plumbing kit supplied with the Nordic Single Tap and Pro 3 tank requires it to be used with a Quooker mixer tap such as the Flex, Fusion or Front, or Nordic mixer tap in a 2-tap configuration. No plumbing parts have been supplied to use it "with your own mixer tap" and no plumbing parts have been supplied to use the Nordic Single tap on its own as a single boiling water tap.
The plumbing kit contains a pressure reducing valve, this valve has 2 outputs on it - the first one goes to the Quooker tank, the second output has to be connected to the cold input on the Quooker mixer tap. My understanding is that this output is a proprietary fitting, looks to be 16mm thread. I either need some sort of adapter to convert it to a normal tap connector, or some sort of blanking cap to seal off the output. I've had a look at the obviouls plumbing supply shops, have not been able to find anyting suitable. I've had a good look through Quooker's website and documentation, can't find any parts that look like they would work. I've also emailed Quooker's service/support but have received no reply.
So the question I have is "how do you install a Quooker Nordic Single Tap either with your own mixer tap, or standalone?"
Many thanks.
Many thanks.
