Hi there, I need to remove a rad to install some french doors. I know how to drain the heating system from reading the wiki on here, turn of water, drain rads....
Q.1 How do you refill the system,, is it just a case of turning the water back on and refiling the system from the expansion tank in the loft.??
Q.2 How do you put inhibiter into the system.???
Q.3 Do I need to join the two tails together to complete the circuit or can i just blank them off..??
Many thanks
Lee
Many thanks
Lee
