Rad. Valve leak
9 Aug 2009
Blackpool
What will the seal be on this as the microbore pipe connects to the rad. Valve. A rubber washer?
If you are talking about the join of the microbore to the valve inlet then in could either be push fit or a compression reducer into a 15mm valve. Can't see from the poor photo.
Need a clearer picture down at the valve, ideally showing where the pipe enters the valve.
