If its a 3/4" then pop into a merchant and they'll sell you the key, or a universal end for a ratchet is much better if you've a few to do. If its 1/2" you'll only need a spanner.
haha ok, I can see I was a little vague there I figured this would be a standard size - as I see it there are the 2 parts to the valve, the part which attaches to either the flow or return pipework, and the part which threads into the radiator itself with PTFE tape wrapped around the thread, I tried to put these in in the highest quality bodged fashion (ie without the right tool) but one drips a tiny bit when the system is cold, so I'll have to disconnect the rad and nip them up properly, meaning that I can't actually get to them now, and wasn't planning on taking them off until I have the right tool in hand... But I did notice that they were meant to be tightened with an allen key or similar inserted into the hole through which the water flows..... I'll stop now as the more I talk the more complicated it sounds, and hope you'll know what I mean
btw I did look at the time if a 3/8 ratchet end would fit but this seemed too big
