- Joined
- 27 Dec 2018
- Messages
- 77
- Reaction score
- 4
- Country
So while doing the usual re decorating, I've been changing all the plugs/sockets etc and I've come across this..
We have a 2.5mm Ring main protected by a 32A RCBO
The conservatory (which was built many years ago), has been connected as an unfused radial into the ring main but only in 2.5mm. The cable run length is about 10-15m max.
The radial..
The conservatory radial has 2 x 1.5KW panel heaters on 13A fused spurs. It has 1 X fused spur at 6amp for the lights/ceiling fan @65W max consumption. Then unfused on the radial is a total of 4 X Twin sockets.
Then... Also off the radial is an unfused spur going into the garden into armoured cable and some plugs with an RCD socket about 30metres across the garden.
Now factoring in worst case scenario, we only use the heaters in winter (both on it comes to approx 13amps and they use run back timers so can't be left on by acciident) and never at the same time we would use the garden power outlet for lawn mowing. The 4 double sockets are also only really there for convenience, we use 2 of them with a stereo and phone chargers at the most.
What's my best way forward with this? I can't connect them to the ring main without massively distruptive work taking place due to french doors in way.
Do I add in a 20Amp RCBO/MCB single way consumer unit into the conservatory to protect the radial? I'm guessing this is outside the scope of what I can do as DIY though? If I get an electrician to do it, would that be an acceptable solution? If so how close should the new 20amp fuse be to where it connects to the ring main, could we install it where the wiring comes into the conservatory (approx 1m from the plug/ring it's spurred from)?
The radial..
