    Dismiss Notice
Radiator bleed valve leaking
Discussion in 'Plumbing and Central Heating' started by AidyTy, 29 Dec 2014.
  1. AidyTy
    AidyTy
    8 Aug 2010
    15
    Thanks Received:
    Country:
    hi there
    The bleed valve on my upstairs is leaking. I have BG coming out on Wednesday to fix it but looking for an interim solution.
    The valve to isolate the radiator is hard to move and i dont want to force it.
    Could I put plumbers mait around it as a temporary solution (would this invalidate my contract with BG?) or should I just keep an eye on the pressure on the boiler and top up as necessary?
    Cheers
  2. PrenticeBoyofDerry
    PrenticeBoyofDerry
    30 Jun 2009
    21,628
    Thanks Received:
    2,383
    Londonderry
    Country:
    If you cannot turn the radiator valves off, your pretty well stuffed!
    Have you tried to nip the bleed valve up a little to see if the leak stops?
  3. Sponsored Links
  4. stef99
    stef99
    1 Dec 2010
    193
    Thanks Received:
    15
    Country:
  5. AidyTy
    AidyTy
    8 Aug 2010
    15
    Thanks Received:
    Country:
    Thanks for your quick reply.
    It is just a drip but a constant drip. I dont want to force something and end up making it worse! I am not DIY minded at all.
    I just want to make sure that in this cold weather and Glasgow is freezing at the moment that I dont have to turn off my heating - I guess I can just keep an eye on the pressure and top up if needed until BG come on Wednesday?
    Cheers
  6. Sponsored Links
  7. Boilerman2
    Boilerman2
    10 Jun 2009
    5,225
    Thanks Received:
    1,015
    Suffolk
    Country:
    That's what I would do, put some old towels under the radiator to catch the leaking water (remember to check them regularly) ;)
  8. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
