Radiator Brackets
J
Johnmelad502
This rad has four of these brackets one either side near top and two on the bottom. One of the bottom ones is broken.
Anyone know where I can get a replacement?
You wont get them any more they are ancient , but your rad can be hung on standard brackets at the back,
Another but. The chances of getting the proper length for an old rad like that is also remote . And it will be a case of just using the top hanging lug.
Most merchants have spare brackets floating about from damaged rads returned or try local scrapy
You can use a normal bracket at the bars indicated.
The vertical hooky separation will be different, so cut through the bracket and fix the ends to the wall separately.
I'm not sure standard radiator brackets will stand out that far but you can have a go with them. Well spotted!!
