A radiator came away from the wall(plaster board),it had been in place fixed for 20 years. A small leak from both in/out pipes occured. I cut the in/out pipes(micro-bore) and just sealed them by flattening & folding them to stop the leaks.
But now my cental heating is not working. I have a tank system with an Ideal minimiser gas boiler approx 10 years old. I tried to make the c/heating come on and the boiler fired up but shut down after 3 secs. The same happens if hot water is switched on, the boiler switches off after 3 secs. The pipe out of the boiler going to the pump gets hot half way to the pump. The pump carries on working and seems ok.
I went into the loft & found the header tank only half full, the ballcock had become jammed with some string which i released & the tank filled up to normal. But now the boiler will not turn on as if a fuse was blown. The electical spur to it is lit, but I am not sure if there is an internal fuse.
So I think the rad falling down & c/h not working are just coincidence?
I think the head tank not filling might be the reason for the boiler turning off after 3 secs?
Now I think some fuse might be blown?
Any help would be much appreciated.
