radiator help needed - size
7 Feb 2006
Middlesex
hi all,
want to replace a leaking radiator. Only prob is that it is 600mm x 1900mm. i cant find this size anywhere!!
i can find 600mm x 1800mm, my question is:
please can someone tell me what i will need to do to fit this size (keeping the orignal water pipes. i guess i need some sort of extender between the radiator and valves. if these are availbele what are they called and in what sizes aree they available?
Sailen
ANy plumbing merchant will sell you fixed or adjustable radiator valve extensions. Try not to use the edjustable ones because they're inclined to leak.
Try Plumbing Trade Supplies for Myson rads - they come in lengths 100mm out of step with the rest.
Some rads are still made in imperial size's and STELRAD also make rads longer than 1800mm
