Radiator insert size
27 Jul 2010
Derbyshire
Hi All,
I am wanting to replace some old radiators that are the same size.
I have noticed that the insert in the radiator has a larger connector than the new one. So to replace the radiator I would have to drain the system (or bung or freeze the pipe) and replace the valve.
Is it possible to buy an insert that would allow me to connect a modern radiator to the old valve.
Hope this makes sense.
Cheers
Are you talking about a 3/4" union nut that goes onto the valve?If so you may find that the old tail that connects into the radiator will fit the new one.
