Radiator Length vs Window Width
12 Aug 2012
Yorkshire
Sorry if this sounds like a stupid question but I am measuring up for radiators for under windows. Do I find the closest match to the window width (i.e. 1600 window = 1600 radiator) or do I allow for fittings/TRV's i.e. 200mm (i.e. 1600 window = 1400 radiator). Not sure what looks best? Is 200mm enough?
Many thanks
Yep makes sense but if I have the option of single / double radiators vs the required output for the room I would probably go for what looks best (i.e. longer single panel radiator)
Not sure now though
Not sure now though
Yes thats the best way to do it , work out the heat output you require then look at different physical sizes of radiators to see which would look better
the bigger the rad the less wall space you will have just go for a smaller double if that's what the room needs
The wider a rad the more even the heat output is. Suingle panels are therefore best.
It looks best if a rad is the same or slightly wider than a window.
There is no harm done by oversizing a rad and indeed it can enable the boiler to be more efficient.
Dont let plumbers put in the minimum size rad that their calculators say will provide the required heat. Choose what looks best as you have to live with it.
Tony
