Radiator mean temperature
Agree with this, there are far too many variables to start worrying about precise temperatures.
If the rads are all heating ok then, if you feel a bit cold turn the heating up a bit and if you feel hot then turn it down.
Measuring individual rooms to a tenth of a degree is pointless, IMHO.
Although I thought the point in the delta (12c for instance) was a means of ensuring the flow rate was 'about right' rather than just temperature
With all rads balanced to 12c delta I'm still only getting around 5c at the boiler, so I'm trying to justify the point in balancing.
No point if the heating is working. Is the house heating up ok, all rads, and warm enough?
Well I could put the boiler on 80c and open all valves and say the heating is working and all rooms are hot but that isn't the point is it?
