The small radiator in our en-suite doesn't seem to work since the heating has started up the past couple of weeks for the winter. It is pretty-much the farthest radiator away from the boiler and the one in the adjacent bedroom is slowest of all upstairs to heat up, but it does get there eventually.
The system is 22 years old, so it's likely not very well balanced, but this rad was working last winter. I've made sure there's no trapped air, and also undid the TRV to check that wasn't stuck - there seems to be some movement in the plunger pin, so I think not. And the lockshield valve on the other side is open. The pipes connecting to this rad don't seen to get hot either.
I'm not sure what else I can do?
