A customer called saying that a rad wasn't working on their system. The system is 10mm microbore. Initial thoughts were balancing, so tried to force it to force heat into the system to no avail, rad only got luke warm at the top with what looked like the rad being classically sludged up with the heat profile. Next flushed the rad out, not much sludge came out, to no avail, rad just warmed up slightly, same heat profile.
I noticed that the flow into the radiator cycles heat wise, so thought that it was the TRV, changed that, no change. The flow pipe cycles heat wise so the radiator never gets fully warm.
The only thing I can think of is that maybe a lump of solder is moving in the pipe and partially blocking the pipe as its moving....not too sure though. So maybe full system clean, but will only do chemical clean not powerflush on microbore system.Not suggested this yet!!
Has anyone ever come across a similar situation? The other rads are piping hot!
