Radiator outlet pipe dripping
27 Sep 2009
Somerset
I have a radiator that has a pipe outlet for draining the system, not sure what the technical term for that pipe is but see attached picture. Anyhow it appears to be leaking occasionally. There seems to be a puddle on the floor in the morning by the radiator.
Can anyone suggest what is wrong?
27 Sep 2009
Somerset
Is the washer just on that bit or is it on the bit attached to the radiator?
22 Jan 2007
On the bit you have outlined check the small square "nut" to the right is done up tight. If it still leaks unscrew it using the nut pulling it all the way out of the fitting and you will see the washer. This will drain the system so attach a hose or catch the water in a basin etc.
27 Sep 2009
Somerset
Thanks. Will it drain the whole house or just that radiator? Is there a technical term for that bit of pipe?
22 Jan 2007
Unlikely to be whole system. If you close off all the other rads you may not get much water coming out at all. Just be quick :)
27 Sep 2009
Somerset
Thanks for your help. Out of interest why do you think it only leaks sometimes overnight?
