Hi all,
My house has a conventional boiler with hot water cylinder upstairs. When we moved in, none of the radiators had TRVs fitted and most had leaky valves, but they all worked. In the last year we have had 3 of the radiators replaced with new, including TRVs fitted (decent brands). Since then we have had numerous issues with the radiators not coming on or only getting lukewarm. Here's the current state of affairs:
All upstairs radiators are original but work fine. All get super hot when the heating is on.
Downstairs we have: 1 in the utility (new - works fine, gets super hot), 2 in the kitchen-diner (new - both rarely get more than warm even with TRVs fully open), 1 in the hall & 1 in the cloakroom (both original, both get super hot, cloakroom occasionally stops working), 2 in the lounge (both original, 1 currently not working), 1 in the office (original, currently not working).
I have bled all the radiators that I can (the office bleed valve is seized, as is the case with a couple upstairs), including the ones that don't work. I also bled the pump and the valve in the airing cupboard. I got very little air out of any of them. The whole system has been drained and refilled at least 4 times in the last couple of months as we've had the new rads fitted/adjusted.
Ideally I want to move to a combi and have all the radiators replaced, but that's a long way off and I really just want to get to a position of stability in the meantime (i.e. all radiators at least working, if not at a uniform temperature). Would welcome any advice on potential causes and solutions to my current woes!
