I'm fitting a vertical radiator within a shallow alcove with minimum clearances left and right. The radiator will not fit if I fit both tails and valves.
Is it possible to fit valves directly to the rad without the tails?
I'll be looking for suitable valves with vertical 10mm feed/return.
Cheers all.
PS - Its a designer rad so a narrower rad is not an option
Cheers all.
