My mission for today is to get a downstairs rad working - it currently has no flow (taken pipe off the TRV so not the TRV) so guess the pipe is blocked.
This rad is piped with 10mm plastic pipe, each pipe is about 4.5m long going up the wall into the bedroom above and is tee'd into the rad there (which is all in 10mm copper). I am assuming the long run to the rad downstairs gives little flow and therefore the pipe has got blocked. Dont know why but feels like plastic will clog easier than copper??
Anyway, I can see the 10mm copper upstairs disappear way under the floor so not sure where it connects to anything bigger. Is it a reasonable idea to change the 10mm Tees to 10-15-10 (if such a thing exists!) and run down to the problem rad all in 15mm copper? I assume copper is a better bet than plastic?
