Radiator temp controller
25 Sep 2019
Hi there I wanted to change this controller for my radiators to a button type controller with a more bigger digital screen. Would I be able to purchase a new different type?
No picture or description of what you want to change.
That's a thermostat. Technically it controls the boiler, not the radiators. It makes a difference as you can also get little controllers for each radiator that work together to turn on the heating just for a particular radiator.
You can replace it with a new thermostat, but there's a lot of choices around depending on what your boiler is, what your budget is and what you want to get out of it.
For example, that's a Worcester thermostat, which means you've probably got a Worcester boiler. That means the Worcester Easycontrol is probably compatible (you should check before buying).
Or you could go for a Hive or a Nest, or probably a dozen others depending on what features you want. So, what do you want?
That's a Worcester DT20RF system. It works in tandem with the programmer/receiver that's fitted to the front of the boiler.
There is a DT10RF which is similar though not sure if the thermostat would pair with that receiver. Possibly a call to Worcester and tell them what you have, they may be able to suggest what other thermostats will pair with that receiver.
I want like a button style digital screen thermostat. So it is easy for me to increase the degrees and decrease it when turning on/off the radiators.
