Where abouts should drain valves be put on the central heating system - i.e. on what radiators. I assume the lowest point or the ones furthest away and if there is more than one ring then on each ring. The lowest point is under floor but I imagine most of the water would be sucked out by pressure. The towel rails are all higher up than the radiators so I assume they don't need one.
Are there building regs about this?
