Radiator Valve Tails
24 Jan 2007
Sussex
Getting round to replacing a radiator that was removed a couple of years ago when the room was being decorated. The distance between (inside) the valves is 750 mm, I've puchased a 600mm wide rad, but need to get some valve tails.
1. These are the valves pictured. One of the pipes was slightly kinked when the radiator was removed, will this be okay when a new rad is fitted?
2.Will valve tails for these valves be easy enough to source ?
3.Will I be able to get valve tail extensions that are long enough (approx 10mm not including valve tails)?
Sorry for all the questions.
Mark
I hope you are going to replace those dreadful valves!
