Hi all,
I've recently had a combi boiler installed, but the radiator in my daughters bedroom is make a noise (rattling pipes) after I've had the heating on for more than 30 minutes. On a couple of occasions I've bleeding the radiator and a lot of air come out, which seems to solve the problem. This morning the same thing happened rattling pipes so I turned the heating off to stop the noise. I bleed the radiator again but no air came out. I thing the twist valve(temp setting for the radiator) is faulty on radiator. It's either on but by twisting it a bit turns no hot water goes to the radiator. Can I just replace the twist valve that screws onto radiator feed or would I need to replace the t piece that links from the water to the radiator where twist valve screws onto?
