radiator
17 May 2007
Is it possible to loosen a radiator and lower it to the floor to decorate behind it without having to remove it completely :?:
yes it is, but if it goes wrong :)
best to drain it and remove it
Thanks for the advice,how easy is it to remove a radiator :confused:
not hard
shut off the valves at each end to the rad.
crack the joint BETWEEN the Rad and the valve, but only enough to let the water dribble out into a bowl or summink
you may need to open the bleed poitn a WEE bit to facilitate the water
job done
failing that get someone who has done it before to do it for you
