Hi all. I recently had a new programmer fitted to my system (Drayton LP722) and it worked perfectly for months, independently running the hot water and the central heating separately from each other.
On Christmas day (of all days) for some reason the radiators turned on when they shouldn't have. Now when the hot water comes on for some reason the radiators start getting warm too. They don't really get very hot but it appears for some reason they are having the water warmed up.
When the heating turns on, despite the programmer turning it off as per the digital display, the pump does not stop and it will run for hours and hours, or until I play around with the black bit of plastic sticking out of the blue plastic casing (as in the photos). I don't know what this part is or why it turns off when I play around with it?
I have a very very old standard boiler. I have now turned the heating off completely as it was not turning itself off and using too much gas.
I don't know what you think the problem might be?
Please ask if you need any more information!
Sorry if I have not explained properly.
