- Joined
- 26 Oct 2015
- Messages
- 5
- Reaction score
- 0
- Country
Hi guys...newbie here...I have a problem with our Vokera Linea 28 combi boiler, which is about 11 years old.
I first noticed the problem a few weeks ago when I discovered that the radiators were getting hot when just the hot water was running, even though the CH thermostat was on minimum i.e. 10 degrees.
A friend recommended a plumber, and after speaking with both him and Vokera, it was thought that the problem was likely to be the diaphragm in the diverter valve, so he got a new one and replaced it. It seemed as though this initially cured the problem, (although I cannot be certain that it did), but the problem has now returned again. He came back again on Friday and changed the diaphragm again, supposedly tested the system and left, but I immediately checked it and found the problem to be still present, so he came straight back and seems to think that the diverter valve itself is likely the cause of the problem. However, I came home from work at 7am on Saturday morning to find that our bedroom radiator (and possibly others too, although I didn't check any others) was hot, even though the thermostat was again on minimum, and no hot water had been run since the previous evening !! How can this be ????
