I managed to get heat to a couple of the radiators last night! Having read up as much as I could about how central heating works I poked around my system a bit more.
Basically, on the side of the tank I found a sticker that says:
"This unit fills the boiler and radiators automatically from the ballvalve through the primary feed and expansion tank."
Then, using a mirror and a torch, I looked in to the tank with the ballvalve and saw, at the bottom, two pipes sticking up. The water level covered one, but the other was sticking out. I also noticed that there seemed to be a mark on the side of the tank where the water (maybe) used to come up to.
So, I figured that, until I took my radiators off to decorate, there had always been enough water in the system. And, over time, maybe the ballvalve level dropped, so less water was being held in the system? So, when I put the radiators back on, there wasn't any new water being able to get into the system to fill it up...
I held the ballvalve down to fill the tank some more, until the pipe that was sticking out was covered and then started the heating. Result! I managed to get heat to the first 2 radiators on the circuit (with the rest turned off).
So, now I reckon I have to gradually fill the rest. Any pointers about the best way to do it?
Also, do you think what I've described above sounds OK?
