Have just fitted a new ladder type towel rail in the bathroom, so drained down the system, and now only half the rads in the rest of the house are heating up.
System is conventional, ie not combi, oil boiler and header tank in loft.
Pumps appear to be working and rads have been bled individually. Also tried opening what I think is a system air vent next to the hot water tank upstairs (1ft vertical pipe) but barely any air came out.
Dave (gas4you) suggested a massive air lock in my related post of yesterday, which seems the most likely.
My only option seems to be to drain the whole system from the very lowest point (house is on three levels and I was draining to the lowest point of the second level previously) with the water supply left on into the header tank, to run water right through and hopefully clear it - but obviously that is going to be a pain and time-consuming.
Is this a wise move or does anyone have any other suggestions?
Cheers.
Brian
Cheers.
Brian
