So, a few days on. That doesn't seem to have made a great deal of difference.
I can turn rads on and off and push though to others but I only seem to be able to heat up two or three at a time.
I've not spent a lot of time watching the boiler until recently. The gas kicks in, the temp goes up to around 70-75, the send pipe gets hot, it runs fopr a few minutes like that then the boiler knocks off until the temp gets back down to about 45 then it all starts again. The return pipe never gets past tepid. That all normal?
The other thing that has happened now a couple of times is that the water light comes on when the water is drawn and then won't go off again when the water stops. Turning off the boiler for a couple of minutes resets the system and away we go, (the reset selection on the selector switch does nothing).
EDIT: I now have the two rads cranked up in the living room (one at the front of the system and one at the end) the thermostat turned up and pretty much everything else turned off. (The bathroom won't turn off but everything else).
The Send from the boiler is still getting mad hot and the return hardly warming at all. The living room rads are warm to hotish.
Hmmm.
Hmmm.
