Follow up message.
Refurbishment in progress and going well.
One problem has been that when using 50mm insulated and plasterboard getting the right length of screw has proved difficult. Partly this is due to the fact that when the battens where originally fitted they weren't at 16 inch centres and when the new wall coverings are in place locating the battens accurately has proved difficult. Have tried to mark the position on the celing and floor but even so go slightly off and the screws ( 70mm drywall )have nothing to bite into and even at best there is a minimal amount of bite.
In hindsight should have taken the battens down and refitted but got too far into project to start all over again.
I want to put some light fixtures on the walls i.e a small display case and some tools and wondered, given the batten location & depth problem when using normal screws what the best type of plasterboard fixing I could use.
Have seen some that screw into the plasterboard, think they are called Redidrive but would these be OK with the insulation board in place as well.
Is there an easy wall to accurately locate the battens behind the insulation/plastwerboard.
